Screw ?
23 Feb 2011
Derbyshire
Hi Guys
I need to get a plasrterer in to plaster most of my house due to flood damage
To reduce the cost I have decided to do as much of the work as I can myself
So I've removed the old ceilings and cleaned and de-nailed the wooden beams
So now its plasterboard time :) Am I correct in thinking that
1: Straight edged plasterboard is best for me, rather than tappered
2: Screw the boards is better than nailing (What size screw nail would I need)
3: The darker side of the boards goes next to the beams
4: I should stagger the plasterboards
5: Do I just use standard plasterboard ?
Any advice would be greatly appreciated
Mike
stagger the joints like brick work
white side out ready for plastering
dont nail it m8 or it will pop all over the place
50mm screws
12.5mm plaster board
taperd edge or straight adge is fine as youll need too scrim the joints anyway
use norm plasterboard in norm rooms and fire board in the kitchen
moisture board in the bathroom
you say your looking for a plasterer i may be able too help you out
if your looking too save money and labour for me ill come over and help out skimming let me know
my number is 07536957847 jon
more pics will be nice
8FT/4FT 12.5mm plaster board id go too
WICKES/B&Q and same for plaster too as the price drops when you buy 5 or more
if your trying too get the boards up on your own get 1/2 dead man props too help you out
plus what is the work just reskiming or is it float & set
is it a 2/3 bed house flat the more insight you can give us the more we can help you
1: Straight edged plasterboard is best for me, rather than tapered
Do your plasterer a favour use 12.5mm square edge boards
Always use screws, never nails; fix every 150mm – 200 mm max & 38mm is all you need - 3 x board thickness; but no problem with using longer. :wink:
Yes &, depending on whose boards you buy, it even says “plaster this side” :lol:
Yes & board longest edge across the joists; if your joists are 450mm spacing no need for noggins at all (as long as your skimming) but if 600mm, use noggins at exposed edges & around the 2 edges or go to 15mm boards.
Mostly you’re OK with standard 12.5mm boards as far as BR’s go but it depends if you want additional sound or fire proof qualities; the difference in material costs at this stage is not than much so your call really. Use MR in bathrooms but it’s not really necessary for ceilings as long as you skim it.
What happened to your insurance?
i was tought too use mb in wet rooms and fb in hot rooms
sorry forgot too say about spacings my bad
if your trying too save money then why not dryline the lids (tape & joint)
is it insurance work as its flood damage
Thanks very much for your advice plstering, by tape and joint do you meen
I should use the stickybacked plasteres tape to seel the joints ?
It should have been but they wriggled out of paying :twisted:
Its a 3 bed house, not sure what float and set is sorry
question? does the house have a) Historical merit? B) listed?
as it was originally lath and plaster and you are permitted to board and skim, use 15mm board as the 3 coat lime work wil be at least 20mm thick and you will be left with and awkward patch al around the ceiling line unless you opt to cove.
plus the joists tend to be under sized and as they have been affected by water damage i would herringbone the joists prior to boarding to a: strengthen the ceiling and b:stop the joists twisting when they finally dry out.
Hope this helps a little?
I'd be very interested in seeing so pictures of a herringbone strut on a 3x2 on 14" centers as is in the picture. I'd go with a strongback and noggins is there is an issue.
hence the link to fulfill your interest  8)
The OP with the problem put the pictures of the job in question in his first post. " :roll: "
I saw that, thats why i replied :roll: but thank you for pointing that out :lol:
I've started to remove plaster from walls now
So just a quick question :)
Would a plasterer plaster straigh on the these walls
Or would it be best to screw plasterboards straight to the walls and then scim the boards
Sorry if its a daft question but I'm learning has I go along :D
Dining room wall
you ned to dot and daab the walls or float and set the walls
how much work is there m8 m8 ill pop over and do it for you or with you and show you how too do it
