Chime on Scantronic 9800+ stopped working after service.
11 Jun 2010
London
Hello,
I just overhauled/serviced my 9800+ panel,i.e Powered Down, changed battery & replaced old external sounder.
On powering up, everything is fine, except that the chime on the front door (zone 1) has dissappeared.
I have checked the programming, the chime attribute is programmed into zone 1, so I can't worki it out.
Also the system is set that I get both L/S & keypad chimes, but the L/S chime does also not work.
Also set it so I only have keypad on chime, but that also does not work.
Any ideas what could be the problem?
Kind regards
Turn it back on .
User Code + 7 + Clear
You're the man Europlex! :D
It worked!
Silly me for not looking at the user Manual :oops:
I flicked through the install manual several times, and all this time the answer was in the user Manual!
Thank you very much Europlex, you've made my day!!!
regards
Turn it back on .
It worked!
regards
Steady now,
glad that's all it was. :wink:
