J
johnsville
Hi, a built-in oven, consumes 3.6 kW. It needs 20A protection. It is small enough to be taken off the ring main in the kitchen. Running a cable for it back to the CU is impractical, a massive job, so off the ring it has to go. there is enough capacity on the ring.
At a push a small 2 way Wylex CU taken off the ring, with a 20A mcb, in an adjacent cupboard can be fitted. I would rather not though. There are 40 amp DP isolators available that can go over the worktop in standard metal boxes, which is what I would rather have. But how do I get the 20A protection. Fuses only go up to 13A, a so a fused spur switch is out.
My prime question: are there any dedicated isolators with 20A fused protected available that fit into a normal recessed metal box?
Another point. This metal Wylex 2Way CU. Can it be flush mounted with the front plate flush to the wall?
http://www.screwfix.com/p/wylex-2-way-metal-main-switch-consumer-unit/61591
Screwfix Product Code: 61591
Thanks in advance
Thanks in advance
