Replacing Water Butt Tap
27 Apr 2011
West Midlands
Can anyone guide me on how to change a water butt tap. I currently have a Brass tap, which has seized up. I am planning on replacing it with a quater turn plastic tap. I cant get my arm to the bottom of the butt to hold nut.
Can you please let me know how I am supposed to change it, or is cutting the tap the only option?
Thank you
Thank you
go to any good plumbers merchant and ask for a butt plug wrench. They will know what you mean.
I rang my local pluming centre and they said that they have never heard of one.
He did however suggest a box spanner?
I was also thinking if If I could get hold of an extending ratchet and the correct size socket for the nut do you think that will work?
Thank you
A box spanner from a plumbers shop - held in a set of water pump pliers should give you enough length to reach :idea: OR long bar - not extending ratchet - and a socket will also do :wink:
I am currently having a looking for a long bar/ Power bar and have come across:
http://cgi.ebay.co.uk/1-2-SWIVEL-HE...s_Equipment&hash=item5d2beddc47#ht_2043wt_905
I am wondering what is the best size drive to get?
Do I need to get every one or is there an adapter I can get so I can use the one bar with different drive sizes?
Apologies for all the questions, I just want to make sure I am getting the correct item for the job.
Thanks you
The one you have highlighted is correct :idea: Half inch Drive - commonest socket drive size - and you can get a socket for your car wheelnuts too. Look @ a Boot sale before you spend £25 ( Britool is a good make though :wink: ) quite often perfectly good tools are on sale @ boot fairs
Tip butt over and crawl inside , get another to hold tap from outside, or clamp with a G clamp or similar. :wink:
Yep - this is what I did. Crawled half inside, held nut with wrench and got wife to screw tap onto it from outside. Easy apart from the struggle to get back out again! :wink:
