Ive constructed an oversized shed and now running in power.
I cant get access to the DB but can get access to the henley block, So was going to branch out of the henley block into a 60A Wylex Switch fuse and then from that to a new DB into my Shed.
Run 6mm SWA
The run is 40m
16 spot lights (LED 7WATT LIGHTS) (1.5mm radial)
6 sockets (2.5mm ring)
4 Dimplex duo 1.0kW / 1.95Kw radiators
Also considering installing a Sunbed but this is when i might have to up my cable from the switch fuse to the DB.
The sunbed company recommend a 16mm going to a rotary isolator from my DB on a 63a breaker.
Need help asap, About to the order cable
Thanks everyone
Run 6mm SWA
The run is 40m
Thanks everyone
