hey guys,
Seems like there's some knowledgeable sparks on here so wondered if i could pick some brains about how others would go about doing this particular job ive got.
the job is changing 2 db's. ive changed plenty of CU's and db's before but this is bigger than my usual. and yes im a proper sparks ( apprentice trained with 2360,2381,2391 ect....)
the current setup is.......
a 4 core swa 120mm (wired from a bussbar chamber protected by 800A fuses in each phase). think the rating of this was 267A per phase conductor, and yes i can see the danger in this.
this goes to a tripe pole isolator (fused with 100A fuses) which feeds 2 db's.
circuits in db 1 are 3 x 30A ring mains, 1 30A submain, 5A timer buzzer, 4 x 63A three phase socket outlets incorpaating switch disconnectors. and 1 roller door supply currently on a 10A tp breaker.
circuits in db2 are 6 x 63A sockets and switch disconnectors and 3 lighting cicuits for high bay lights 400w lights.
the boards are 12 way each. rest of ways not mentioned are spare.
anyone got any input on this?
obviously im going to try fitting an isolator after the bussbar chamber to protect the supply cable for the boards. then planned to split the cable to feed 2 seperate local isolators next to the boards, one for each.
am a bit unsure if this is the best way of doing thing?
also has anyone any input into the ratings of isolators and boards i should be using taking into the cable thats there? or anything else they think may be important to consider.
appreciatte any views.
great site by the way.
