There's a problem here:
If so that makes it 1mm² cable - no way should that be on a 32A breaker.
the cable supplying the original double socket is about 2.5mm to look at.
Not sure why, at the time, you thought the cables were "2.5mm", but you now seem pretty definite that the largest dimension is 4mm.not sure which supply exiting the CU goes to heating but all are around 2.5mm.
