As you will realise, that has been my point.In this thread it has been a lot of tongue in cheek. But it does seem strange that cable installers cannot see that if two wires are connected to the same length of pipe they are both connected to the same galvanic (metal) node and a node can only have one designation.
I'm not aware of anything in the regs that says that such a pipe 'cannot be earthed'. Indeed, as you say, the boiler itself, which is in continuity with attached metal pipework, would (assuming it had an electrical supply) normally have to be 'earthed' (I've never heard of a Class II boiler). If you're looking for an anomaly (in engineering terms), the requirement to 'earth the boiler' (connect it to the CPC of its supply) exists even when the attached pipework is connected to the MET (via a 'bonding' cable). However, I guess that this is just 'belt and braces', and also to ensure that the boiler remains 'earthed' even if a plumber disconnects all pipes from it whilst it is still connected to an electricity supply!A cable installer with a book of regs says a water pipe to a boiler cannot not be earthed but must be bonded to the MET.....
Kind Regards, John.
