New Alarm Install
Hi Guys,
If I add the IP interface, will the wintex software connect though this rather than needing an RS232 interface?
Cheers
Will
Hi Will,
Yes, wintex will connect via the IP interface, no need for serial. I seem to recall last time i used the Premier 48 that the ip module had to have its power cycled in order for the changes made to it via the remote key pad to take effect. This would be IP, DHCP settings, subnet etc....
The wintex software is really useful - saves alot of time.
Joel.
Hi Will,
Joel.
Perfect, I think we have a system sorted, found some great prices for all the kit too, well happy.
Thank you all for your help, looking forward to installing it now.
Now onto the front door CCTV research.
Cheers,
Will
Just a little warning.
Single button setting is fine, unless you add small children.
One hits a button and off goes the alarm. Just something to be aware of if you have rug rats :D
Cheers, lucky I live alone, so will be no issue for me.
Thanks for the heads up.
