Upgrade to Toilet flush system
8 Mar 2007
Yorkshire
Hi all,
Im looking to upgrade my toilet flush system and was after some advise on products to use. The flush is quite old and doesnt flush in an instant like some of the newer ones so time for an upgrade.
Picture of current system
Would appreciate some giudance on what to replace with
Thanks in advance
You need to remove the cistern from the pan and remove the plastic nut on base of cistern to remove the syphon then you can either change just the plastic diaphragm or fit new syphon for what they cost.
Dudley turbo 88 is a good one as it seperates without stripping the cistern down.
about £18
or a basic opella that is one piece like yours is half the price of the dudley.
yours is an ideal standard.
but measure the height before getting a new one as they come in different heights.
I'd go for the Opella, the only advantage of the Dudley is that they are 2 part so you can change the diaphram whilst still in place. As it's an easy job if you have go do it again, not really worth forking out for a Dudley turbo
Ps - if you really want to upgrade, you could install a push button siphon
Fluidmaster flapper valve. Exceedingly easy to maintain.
On the subject of easy to maintain syphons, the CME/Macdee Metro also seperates in the cistern, but is waaay cheaper than a Dudley Turbo 88.
The Turbo 88 is dual flush though, whereas the metro is not.
