I hope someone can advise me. We've had a little damp problem in our living room for a few years now. It started with the paint blistering. I sanded it down, slapped on a bit of damp seal and painted over it. It seemed to do the trick for a while. It is an internal party wall and the patch is about 3.5' above the skirting.
It came back again so I repeated the same thing.
Well it's happened yet again. Only this time round, while sanding back I noticed that the problem was a little more extreme. I ended up pulling off loads of peeling paint to reveal a lovely big bald spot about 2' x 3' with patches of white causing the blistering. Salts I believe?
I brushed on the damp seal as usual but the blistering appeared again within a day and the coat of damp seal didn't bond properly and just peeled off in one big sheet and felt like a deflated baloon
Here is the patch:
You can see were I painted on the damp seal (The yellow is the previous wall colour).
And here is a close up of the salts bubbling up to the surface:
Is this going to be a major re-plastering job, or is there something I can use to stabilise the salts so we can just sand it and paint it?
Obviously we'd like to sort out the damp properly, but funds are a little scarce at the moment
Here is the patch:
