Slow Cold Water (Baxi 105e)
5 Jul 2011
Nottingham
Recently the cold water has been very, very slow - this in turn results in very slow hot water (which is provided by our combi Baxi 105e boiler).
Location wise we're in the East Midlands hence there isn't hard water (a possible cause I thought).
I can understand the hot water being cold if the pressure is low (which it isn't) however this is effecting the cold water specifically and hence having a knock on effect on the heating and speed of hot water as well.
Any suggestions?
Low cold water flow should have no effect on your heating.
Did the problem occur suddenly or has it got worse over time?
Has any work been done to the main in your area recently?
Are all outlets affected?
Are your neighbours also experiencing problems?
Have you upset anyone who might have subsequently turned your stopcock down as a prank?
does cold tap still come out at normal rate
Nope, cold water is very slow also.
Its happened pretty suddenly (over a weeks period really), no work in the area as far as I'm aware, all cold taps are affected including the outside tap, no chance of anyone touching the stopcock.
Are you on a water meter?
have you got kids or had them round and stop tap on show
if so give turn see if it opens
Neighbours aren't experiencing any issues as far as I'm aware.
No one has access to the stopcock without having to move the dishwasher so no real chance of the issue being as a result of that.
Sounds like its an issue on the way into or just outside the property.
dishwasher take it out check the stoptap posibly cuased the problem with viabrating and turned stop tap or knocked the rubber off inside
Have you actually asked them or are you just assuming they aren't experiencing the same issues because they haven't told you they are?
Have you checked your stopcock in the road, which is the one I was referring to earlier?
I agree, and if you could possibly answer all the questions I ask we'd make progress much more quickly here...
So, have you got a water meter? If you have, turn off your indoor stopcock then go out and look at it. Is it still turning? If you haven't, turn off the outside stopcock then open your kitchen tap. What happens?
