16x10" wall tiles 8 or 10mm notched?
4 May 2009
Surrey
In a week or so I'll be doing our bathroom and wifey wanted 16x10" tiles with 24x3" border. Just checking which notch depth I should be going for.
Some walls are skimmed others are just render.
The border tile is a couple of mm thicker than the main tile. Since its smaller am I going to be ok with a smaller depth to even it out?
I've gone for 3mm spacers
What weight are the tiles, plaster has a maximum limit of 20 kg/sqm but that includes up to 4 kg/sqm for the adhesive/grout so anything over around 18kg/sqm & you could have a problem. The render should be OK, as long as it’s sound it will take up to around 40 kg/sqm.
You must use cement powder adhesive only for tiles that size not tub ready mix or it will take an age to set & sometimes never does. When using powder addy, plaster must be acrylic primed to avoid a reaction between the cement in the addy & gypsum in the plaster. I usually use Rapidset but it only has a pot life of 45 mins so only mix up as much as you can use in around 30 to give you time to clean your tools & bucket between mixes (very important)
For the size of your tiles you need a solid bed trowel; I generally use a thick bed trowel - 20mm round notches, 10mm deep, at 28mm centres. On really flat walls you can use a thin bed trowel - 10mm tapering notches, 5mm deep, at 12.5mm centres but stick with the larger one if not sure as larger tiles need a nice flat surface or they can end up all over the place. The border will be fine with a thinner bed but let the adhesive set before you start tiling above or it could all start moving about.
I advise you read the Tiling Sticky & Forum Archive posts before doing any more work or buying materials, it could prevent you making disastrous & potentially expensive mistakes. It’s important to use only quality trade tilling materials of the correct type for your tiles & tile base; cheapo own brand & DIY stuff is mostly crap.
Hi Richard, thanks for the reply.
The tiles weigh 1.2kg each and are 10 per sq m. That leaves me with some headroom on the weight front.
I was sold some cement based powder adhesive by tilebase (where I got the tiles) which is weber.set plus. I've only ever really seen Bal bounced when I've looked before but I never really looked that intently. It seems to be a reputable adhesive from my searches post sale.
I noticed on the packet that it mentioned priming plaster so I'll pick some up before I start.
As for trowels, am I correct in my thinking that a solid bed trowel differs from a square notched trowel because it has different shaped notches? A square notch will maybe give 60% adhesion because it doesn't flatten as easily as a round or tapered notch which maybe offers a 90%+ adhesion?
As long as the plaster is sound & isn’t blown then you should be OK.
The Webber Set will be fine.
As I said, standard procedure for powder adhesive over gypsum plaster/plasterboard; it must be acrylic primed to avoid a reaction between the cement & gypsum in the plaster. Generally though, don't prime unless addy manufacturer recommends it.
Yes more or less, it’s to do with the shape, depth & pitch of the notches. A solid bed trowel will give >100% adhesion if properly used & there is an even bigger one when tiling really large format tiles on floors. Good adhesion & support is essential for floors & on walls in wet areas but you can use a standard, round notch trowel (6mm round notches at 12mm centres) for walls in dry areas which gives approx 70% coverage. It will save a bit of addy but, personally, I never bother & stick with the thick bed trowel.
Thanks once more Richard.
I've picked up a Rubi 10mm U notch trowel, a marshalltown grouting float and a whisk for the adhesive/grout.
Blimey mate that’s serious gear for a one off DIY :eek: I’d have gone with cheapo BNQ, they do a reasonable plastic notch trowel & sponge float & I think the pair come in at less than a tenner; they would have served you perfectly well & lasted long enough to tile your whole house.
If using a drill whisk for the addy, keep it at slow speed & don’t over mix or "pump" it or you will introduce too much air & drastically shorten the pot life/set time. You don’t need a mechanical whisk for grout, I use a wooden kitchen spoon :LOL:
I've dropped 2k on a bathroom, 35 on a few tiling bits that i'll have for the future is nowt. And I like proper tools ;)
I'm only 26 so they'll get plenty of use over the years!
Thanks once more for your help. And thanks for taking the time.
