That's the obvious reason, and I've no problem with that, but... I'm just a bit worried about potential problems that will probably never occur, but may...
A lot of people have built porches around their front door area, which actually makes the meters internal and not accessible to meter readers etc so I'm guessing it's not a 'legal issue' to lock it.
I submit my readings monthly anyway.
I'm just not sure what type of lock I'd need.
I thought about ones like what windows have, with push locks that stop the handle from moving when the button is pushed in, however the current handle is on the frame of the door and not the door bit, so something like that wouldn't actually do anything, unless it had a notch that keeps the door shut.
As you can tell, I'm limited by my ability of describing things, so I've no idea what I need to be looking for. What I want probably has a simple name...
you might consider fitting some kind of window in the door so the meter reader can do his job
I believe the utility co's have an anti-vandal lock they fit to cabs in high-risk areas. You could ask for one. Does your have a budget lock operated by a triangular key?
if you can get a budget lock to fit, operated with a normal triangular key (the meter readers carry one) you will have brought it up to normal standard.
I doubt it would cost as much as £5
search for "meter box lock" or "meter cupboard lock"
Gone for a locking cockspur for £4 on ebay, will see how that works out.
Currently working out 'window' options for the meter... I'd want it to blend in so have a white 'door' to slide up/pull up to reveal the window and therefore the meter... One for a rainy day...
