- Joined
- 17 Dec 2006
- Messages
- 698
- Reaction score
- 225
- Country
Hi Guys
I'm thinking about trying to remove the cold tap insert shown in the picture here, but it's fairly stuck (maybe limescale):
I've turned off the water supply using the tap isolation valve fitted beneath the sink. So far, the tap insert won't budge with the limited amount of force I've applied with an adjustable spanner. What I'm worried about is using too much force and damaging the tap pipework, as I don't have the skills to fix broken pipework.
Here's how the mixer tap looks from below:
There are three pipes coming down, and the back one is hexagonal, which I assume is somehow keeping the mixer tap in place. How much turning force on the tap insert do you think this installation could take?
To unscrew the tap insert by applying force, how would you prevent damage to the tap pipework? I'm thinking that putting blocks of wood behind the tap base would prevent rotation, or perhaps buying a special tool to clamp the mixer base would be worthwhile?
Thanks for any thoughts.
