Hello. I worked out the total size and with the existing small kitchen area which is being incorporated into the 8 x4 mtr block, it totals approx. 40mtrs sq. Its all very well insulated and has three large glass areas(bifold doors, window and roof lantern totalling about 12mtrs sqr ,the glass being of the required spec) .
The plumber has fitted what i would describe as rather inadequate looking rads , one 600x 800 double panel double convector and one single panel single convector 450x 1200 mm.He reckoned it would be enough because of the insulation and the fact that modern rads are "very efficient" Now I have done a calculation using online tools and it would seem a room this size would need about 14k+ BTU heat emission to warm it sufficiently whilst what I have had fitted would only reach about half that amount ,7k. Because one is fitted under a window i am restricted by height to about 500mm max.As far as I can see i have one of two ways to go , either a 2000 double convector, double panel rad ,which just about adds with the other existing one to the req 14k ,or I buy a triple convector 1600mm rad.Either way the cost would seem to be about £340
Could someone please advise me on this? thanks
