Hi folks, I hope you can help.
I've been noticing a constant trickle of water running down the back of the toilet bowl for the last month or so, it comes down in four separate places along the back.
I've enclosed shots of the cistern and the "plunger" part attached to the lid via the blue tube and was wondering if you kind folks wouldn't mind taking a stab at what the problem might be and how to solve it. I've heard this could be something to do with the tube or a washer somewhere on the assembly, but I've no idea really
When I leave in the morning the cistern is at the max fill (6L) marker, however when I get home it's sat at the minimum marker (4.5L), what I find a bit odd is the fact that the plunger doesn't kick in to fill it back up as on the old "ball" cisterns the more the level dropped the more it would put back in....
Ordinarily I wouldn't bother about it as it's not doing any harm (leaking inside or overflowing outside etc) but I wonder how much this constant stream is costing us given that we're on a metered system!
