Cut large marble backplate
6 Aug 2011
Yorkshire
hi guys,
i'm about to get a nice looking marble fire surround, with back plate and hearth. The only problem is, the backplate does not have a cutout to put in the flue of a normal heater or an insert.
Is it possible to cut out a large piece of marble backplate or get it cut professionally without breaking the marble or is it just not worth the headache?
It is easy to cut, assuming it is marble. Use either a masonry disc in an angle grinder, or preferably a diamond blade. As it is a one off, normal discs would be more economic, and you won't use more than 2.
If it is granite it is worth buying a diamond blade. Normal discs will wear quickly and you will use a lot. With a normal disc, you will tend to skid and damge the panel.
If you don't have accesss to a grinder, pop into a local fireplace shop, and they may do it for you. I would charge about £30 - £40, but it would be at customers risk.
Some shops wouldn't be interested, and you would more than likely have to get the panel to them.
Good luck.
thanks gasman.
I have a cheapy tesco grinder (will this do the job?) :-
http://direct.tesco.com/product/images/?R=207-0283
someone said to me that to reduce the liklehood of cracking, whilst using a grinder with a diamond blade, i should get a second person to get a cheap plant spray bottle and spray a small amount water mist to help avoid too much friction (avoiding any electric parts of course :lol:).
Does that sound like a good idea?
Sorry if this is too late:
thanks gasman.
Not on granite, but should be okay on marble, nut don't force it.
No. Totally unnecessary.
