What do you think is the best way for a DIYer to fix thin coat angle bead to dot and and dabbed board?
Staples/Screws/Adhesive?
--- long waffly explanation bit ---
Staples
A site I found suggested staples were the best. I've tried with some 12mm T50 staples and my staple gun, and although ok it's very tricky to a) line up the staple gun with the very edge of the hole in the beading and b) fire the staple without moving the carefully aligned length of beading.
Plasterboard screws
25mm plasterboard screws I think is my favourite option - they cause more damage to the board than the staples but they're easier!
From a few test pieces I've done it looks like the screw head will be *really* close to the surface
Adhesive
Using plaster dabs to hold everything in place seems popular. Can this be done well in advance of actually plastering, I'd really like not to be worrying about getting edging straight when I've 1/2 a bag mixed up and trying to skim coat
Staples
Plasterboard screws
Adhesive
