Hi all,
I'm in need of some advice...
I'm have a suspended wooden floor of which the underneath is a car port and is outside, the upper side of the floor a bedroom. On my architects plans it states;
"Floor joists to receive 12.5mm plasterboard and skim finish to achieve 30 minutes fire resistance. Floors are to be provided with 100mm Rockwool or similar insulation to achieve sound insulation and additional 50mm kingspan kooltherm K3 insulation board over carport to achieve a minimum U-value of 0.22Wm2/K".
I'm nearly ready to do the flooring / carport roof, but do I put the Kingspan on the lowest part of the floor and put rockwool on top, just below the floorboards? Or vice-versa, or doesn't it really matter so long as the kingspan and rockwool are in there?
As I understand the above quote, I'll plasterboard and skim the carport roof, then from the floor above put in the Kingspan, then put rockwool on top, then floorboard the lot. Am I right?
