nails for featheredge
15 Apr 2005
Yorkshire
What size / type nails do you use for fixing featheredge to 3x2 rails?
Quick one! Item number on screwfix too if poss!
The quick answer is toolstation, 68921.
Thats what I'm using for fixing a featheredge fence this week.
Thats 6cm long, I'm guessing you are using thicker rails.
And screws? I thought you were meant to nail featheredge. Just what I read somewhere on here.
Use the shorter ones then. What law is there that says you must use nails. :D
remember 1 fixing per board per rail in the thick end covering the thin end about a 5mm gap to the board for expansion
or to explain overlap say 25mm then fixing a further 5mm away as 30mm
