Which is cheaper to run, a 8.5KWH shower or a combi boiler supplying and mixer head????
It obviously varies but, on 'standard tarifs', I think that electricity may typically cost around 12p per kWh and gas about 4p per kWh - so there's really no contest (not that showers amount for a significant part of most people's fuel bills). I don't really understand electric showers being so fashionable - not only more expensive to run but also 'inferior' (flow etc.).Which is cheaper to run, a 8.5KWH shower or a combi boiler supplying and mixer head????
You're welcome. I'm also 'in the middle of nowhere', with no natural gas supply, but we use LPG. Although a lot more expensive that natural gas, it's still cheaper than electricity for heating home/water.Many Thanks both. We only have electric at home as we are out in the middle of no-where so i am not sure about gas prises and consumption to achive the same effect.
Yes, LPG has a much higher calorific value than natural gas - around 26 kWh/m³ as compared with (I think) only about 10-11 kWh/m³ for natural gas. Unfortunately, the cost comparison I was talking about was in terms of cost/kWh - so the considerably higher cost of LPG is only too 'real'.John, does LPG have a higher caloric value than natural gas? If so does that help offset the cost or have you already factored that?
Another significant difference is that LPG flames are much hotter
What you can't get away from is that increasing the temperature of a certain volume of water by a specific amount will require the same amount of (output) energy (kWh), regardless of the form of heating - or , if you prefer, increasing the temperature of water flowing at a given rate by a specific amount will require the same (output) power (kW), regardless of the form of heating.Although the gas boiler is likely 30kW compared with best electric at 11Kw so while running it uses more power.
As I implied before, I would definitely agree with that.But back to reality I would only fit an electric direct shower when there is no option of using a gas heated one.
Indeed. I probably wasn't as clear as I should have been, but when I spoke of energy and power output, I intended that to mean 'effective output' (i.e. transferred to the water) - and I obviously agree that efficiency will be near-optimal with an electrical shower and appreciably less with a gas boiler. However, the price differential between gas and electricity (per kWh) is so great that I imagine that gas retains a cost advantage in terms of a given amount of water heating.From a theoretical point of view, the direct electric heating probably the most efficient system imaginable, since gas heating has the losses of not capturing all the heat from the combustion and losing heat in pipework and storage tank; and the conversion of energy into heat in the element of the electric shower is as near 100% as we'll ever get.What you can't get away from is that increasing the temperature of a certain volume of water by a specific amount will require the same amount of (output) energy (kWh), regardless of the form of heating - or , if you prefer, increasing the temperature of water flowing at a given rate by a specific amount will require the same (output) power (kW), regardless of the form of heating.
Indeed. In fact, although I was initial sceptical, I've also experienced some quite impressive showers run from 'instant gas heating' (i.e.combi boiler).I certainly wouldn't use an electric; pair of gas boilers, stored hot water and a large pump make for a very good system.
Gas boiler (or oil if no gas available) and hot water cylinder, which also has an electric immersion heater for when the boiler breaks.
