ENTRYPHONE
15 Sep 2011
Dundee
I am looking for advice on replacing my old 'ENTRYPHONE LONDON' (which has quite a few wires) with a BELL 801.
Any help or advice on the wiring would be appreciated,
regards
regards
They are very similar systems.
4 wires in parallel to every handset: common, talk, listen, door release
1 wire from the call button on the panel to the buzzer on the corresponding handset.
Common and talk should be wired as a twisted pair.
Entryphone diagrams are here
http://www.entryphone.co.uk/Literature
You will need Plan 1.
Corresponding connections between Entryphone and Bell is shown here
http://www.entryphone.co.uk/pdf/phones.pdf
If you only want to change the handset then I would suggest a replacement Entryphone handset.
Thank you for the reply greatly appreciated, will probably take your suggestion and purchase a new Entryphone,
cheers!
