Hi chaps, in need of some more advice!
Building a small extension and the outer leaf is the local ironstone. This tends to come with two 'dressed' faces (front and bottom), and can be a bit hit and miss elsewhere.
I noticed a local builder using the same and the cavity was fully filled with what looked like Celotex type insulation or something along those lines. This enabled him to fill any voids and make a level bed for the next course with (what appeared to be) a sharp sand mix. As it 'rested' against the insulation the mix didn't fall down the cavity. This would give a good solid level for the next course. If I left a part empty cavity, a lot of the stone would need pointing and in-filling with pieces to make a level bed.
The builder wasn't there to ask, but it looked like a good idea. The only thing is I thought I might have read about a minimum gap of 25mm or something with Celotex. The builder may have been using a different product so I am not suggesting that he is wrong, just interested in any clarification.
If the insulation had foil both sides and was taped, i.e. a vapour control layer, would that be acceptable for 'full fill' or is it never acceptable?
Any feedback as always very much appreciated.
