Hi all,
I have a main tank with a pump in it pumping into a smaller tank. When the pump in the main tank turns off it continues to syphon down into the smaller tank. I am using a float switch system that I would like to turn on the pump within the main tank when the second tanks level gets to low then turn off via another flat switch when it reaches its level. I am not sure how I can stop it from syphoning back on itself once the main tanks pump turns off..I have seen these
http://www.wickes.co.uk/invt/420182
I am using 1/4" hose of which I think is the same as a washing machine hose?
