Worcester 9.24 Electronic pressure rising
3 May 2009
West Glamorgan
Worcester 9.24 Electronic combi, water pressure rising to 4bar when c/h is on only. With hot water only no pressure problem only water does not get hot enough for a wash! filling loop is turned off and not letting by. Heat exchanger problem?? also water switch?? This is a dinosaur of a boiler I know, cant find a manual for it any where, any comments would be appreciated.
Brian.
Not trying very hard with the manual.
Took me about 30secs.
With the heating off an cold.
When yhou run a tap for a few minutes does the rad nearest the boiler start to warm up?
If so then you need a diverter valve.
Still think your EV is goosed though.
