UPVC cladding - for a porch
16 Sep 2010
Sussex
hi all,
I've got a porch which at the moment is just an angled roof with a wooden bracket underneath. i want to box in the sides and bottom of the roof, to make it enclosed - so i can put an exterior spot lights in the newly created celing of the porch.
I was assuming i could just use some upvc cladding / tongue and groove type materail, as i think this would look the best, but unsure what i should be looking for and where!? any suggestions??
ta.
you will need a frame to fix it as clading is thin and no strength
you need support every 400-600mm dependant on thickness
Once you've done what big-all says, you'll be neededing hollw cladding sometimes called hollow soffit, its the cheapest and easiest stuff to use.
dont bother with wickes it is far too expensive try eurocell they have branches in redhill, hastings and bognor regis in your area a 5m length will be about £8 and they will deliver cheers
they are tucked away in redhill we went all over the holmthorpe estate looking for them wasted an hour looking everywhere :D :D
through the railway bridge turn left through the first gate/opening and about 5th on the left
