Hi, advice is required please:
We have had a new cast iron insert and gas burner installed into our existing (swept and fully functioning) chimney/fireplace. At the time of fitting the damper plate hadn't been supplied.
The damper plate has now arrived and forms a draught-free fit when fully closed. Now that its getting colder we plan to start using the fire, but my concern is this: can I purchase some sort of clip to hold the damper in a suitable open position for a 3kw gas burner, but which easily allows for it to be closed too when not in use? If I push it fully open then the fire doesn't burn well (too much draw upwards if windy etc), and there would exist the possibility of it falling to a closed position which I don't want.
Thanks!
Thanks!
