How much to move an internal soil stack outside?
23 Oct 2011
Yorkshire
Can anyone give me a rough quote as to how much it would be to move an internal soil stack outside, I want to move it because I want to knock my kitchen into my utility room and put one bio fold door in the middle however the soil stack sits between the 2 rooms. It would need to be moved to the other side of the bathroom window which is about 1.2 m wide, the toilet can stay where it is and an external pipe running from the toilet to the new soil stack on a slight slant should be fine, the soil stack can then connect to the drainage which the washing machine currently uses, is there anything I've not thought of?
I have budgeted £2k for removing wall and RSJ and £1,500 for the kitchen door is this reasonable so how much then for the soil stack?
I'm not up to speed on drainage, BUT i seem to think that you should not run grey water i;e washing machine drain into sewer as this kills good bugs at treatment works.
WHERE should you run the washing machine water then????? :roll:
Andy
I would check with Building Control Dept at the local council that moving the stack outside is permitted under Building Regulations.
How do you expect anyone to be able to give this a meaningful answer? You may as well ask how much to move England six inches to the left.
This used to be a DIY advice forum.
i have just had a quote to have this done, £450 . to move the soil pipe fro inside to outside, we wanted it doing to make space in the bathroom and the kitchen. £450 was with me digging out the ground aswell.
Got a mate round who is a bit handy and it cost me £85 and a few beers. To be honest its not a difficult as you may think. id be confident at doing it on my own next time.
Get over to Yorks. and give the OP a hand :wink:
How is the upstairs part of the fixing going to be done?
Does that include a new hole in the wall to connect the upstairs toilet to the outside?
I would have thought £1200 more appropriate if done off ladders! Thats not meant to be how its done now. So add £ 500 for scaffolding.
Does anyone know how my cheapo access tower features in safe access?
Tony
