I often find myself needing to periodically 'shut-off' all flow to radiators on the top floor of my house during the daytime (to save money when lodgers are out) but I will often want the CH still flowing on the lower and middle floors. It is a real pain to constantly turn off-and-on the top-floor radiators so I thought some sort of isolating device in the pipe(s) leading to the to top floor would do the trick. The system is open-vented, and the boiler, pump, HW cylinder and controls are on the middle-floor.
What is the best type of isolating valve to use, bearing in mind the flow could be turned on-and-off once daily? I am thinking a wheel-operated gate valve or 'large-lever'-type ball-valve would be best, but you experts out there may have better suggestions.
Also, do I need to insert a valve in the flow and return pipes to the upper floor, or would one in the flow pipe be sufficient? (on the basis that if water cannot flow, it cannot return!)
Many thanks,
Alan
Many thanks,
Alan
