Which is live wire?
At least here, if found wrong ( and not your fault you followed the other diagram), it does not end in a argument :D
Well done lads.
I can't really resist repeating the first contribution I made to this thread, three or so pages back ....
Indeed, I find it incredible that so many people are arguing about which is the "correct" way round when there simply isn't one. Supply to com. and light on L1 or supply to L1 and light on com. - It doesn't matter!
As for the diagrams on the various manufacturers' leaflets, they're merely representative of how the switches can be used. They don't have to be wired exactly as shown.
In those MK diagrams, for example, for both the traditional and the alternate 2-way arrangements the diagrams show L1 to L1 and L2 to L2 on the switches. But if you swapped the L1 and L2 connections at one end, it would still work perfectly well, the only difference being the relative positions of the two switches for the light being on and off (i.e. both switches up or down for off, or one switch up and one down for off).
Then there is the diagram with an intermediate switch for control from three positions. There's no diagram which shows the use of a second intermediate switch to control a light from four positions is there? So is anyone going to say it would be "wrong" to do that just because the arrangement isn't shown?
Besides, take a look at the note at the bottom of the diagrams for the Albany Plus range and what do you see?
N.B. Terminal positions may alter. The above diagrams are to show wiring layout.
One out of a box today, I don't recall making any claims, other than the correct procedure is to follow MIs!
Yes that drawing is correct, but I was and still am refering to this claim below
You was obviously talking about a switch with L1 and a common terminal and assuming the red was Live
That the standard method used to install a one way light switch is to connect the permanent live to the com terminal and it is also good practice.
Red-Com
Black with sleeve-L1
Are you disputing that?
Well when you do fault finding on large single red wired installs in trunking it does help a lot if you have to trace the live supply and you know what wire it is
One has line in L1 the other C.
The C is the switched, and it is called a switched line isnt it?
Thank you, and can you spot the diference between that drawing and the other one as clearly noone else can. :)
True, there may be good reasons such as this for being consistent within an installation (along with things like consistent use of redyellow/blue or brown/black/gray for 2-way wiring, etc.). But you can consistently put the feed to C and use L1 as the switched output or vice versa without it making any difference.
As there is nothing which evenly remotely resembles a convention (even a loose one), even if you know that the C/L1 terminals have been wired consistently, you would still need to check which is which for that particular installation.
As Paul has just implied, there is actually a potential hazard associated with such conventions, since they tempt people to make potentially dangerous assumptions. Although I'm sure you don't really mean it, what you've written above almost implies that you might make assumptions on the basis of what convention you thought had been adopted - and, as we all know, one can never assume. Even G/Y cables have been known to be used as live conductors!
quite right I would not assume, it would be nice if everyone was the same, but i would follow the L connected back first before the common, but obviously if some of the blokes here wired it I would end up at the light rather than DB :)
I give up now, all i wanted was to see this MI from pbod with the switchline in L1 or L2 on a one gang switch as i have never known or seen it, i know its all irrevolant realy but i like someone to back up there claim.
Maybe one day
