Because in the two diagrams which have coloured wires, the "L" and "SW.L" labels appeared to have been swapped into the wrong places.WhyBut I think MK made an error on Rockys piccy.![]()
Kind Regards, John.
Kind Regards, John.
I can't really resist repeating the first contribution I made to this thread, three or so pages back ....
N.B. Terminal positions may alter. The above diagrams are to show wiring layout.
One out of a box today, I don't recall making any claims, other than the correct procedure is to follow MIs!
That the standard method used to install a one way light switch is to connect the permanent live to the com terminal and it is also good practice.
Red-Com
Black with sleeve-L1
Are you disputing that?
Indeed, I find it incredible that so many people are arguing about which is the "correct" way round when there simply isn't one. Supply to com. and light on L1 or supply to L1 and light on com. - It doesn't matter!
Wot he just said
One has line in L1 the other C.
The C is the switched, and it is called a switched line isnt it?
Well when you do fault finding on large single red wired installs in trunking it does help a lot if you have to trace the live supply and you know what wire it is
I've lost track here - The difference between which two?Thank you, and can you spot the diference between that and the other one as clearly noone else can.![]()
As Paul has just implied, there is actually a potential hazard associated with such conventions, since they tempt people to make potentially dangerous assumptions. Although I'm sure you don't really mean it, what you've written above almost implies that you might make assumptions on the basis of what convention you thought had been adopted - and, as we all know, one can never assume. Even G/Y cables have been known to be used as live conductors!Well when you do fault finding on large single red wired installs in trunking it does help a lot if you have to trace the live supply and you know what wire it is
Yep I still stand by thatThat the standard method used to install a one way light switch is to connect the permanent live to the com terminal and it is also good practice.
