I have just purchased a Dimplex 2KW downflow heater for which the wiring instructions are not all that clear, Could anyone please advise as to what is needed to intall wiring.
SUPPLY CABLE IS NOT SUPPLIED WITH THIS APPLIANCE AND IT
SHOULD THEREFORE BE INSTALLED BY A COMPETENT
ELECTRICIAN IN ACCORDANCE WITH THE IEE REGULATIONS.
It sounds like you do not qualify. Get a man in./
The heater will need to be connected to a 13A supply in the bathroom through a double pole isolator. Do you have one? If not you'll need a competent registered electrician to fit one. He will also need to install an RCD to comply with BS 7671.
