Nerd chainsaw job of the week
7 Feb 2008
Northumberland
Two bolts hold the chain bar onto the side of most chainsaws. The bar is secured by flanged nuts, and the chain tension is adjusted by some sort of sliding mechanism that pulls the chain tight.
Don't over tighten or strip the threads on the bar bolts!! If you do, you'll often have to strip the entire machine and split the crankcases :shock: to replace them...they pass through the crankcase and are held by means of their heads being square. Some of them actually reside within the chain oil tank.
Try to show a profit on that job.....hell, its only a stripped thread, after all.
John :D
Sounds like a post born of bitter experience. :(
I've got one in the workshop now sitting waiting for me to repair or rather replace the snapped adjusting bolt :cry:
The adjusting screw can be replaced with the chain bar off and any guide cheeks taken off too, so that shouldn't be too bad!
I reckon to replace my chain bar stud (next time) I'm going to knock it back into the oil tank, then fish it out. I'll try and get the new one in by somehow tying some thin wire to the thread and see if I can pull it into place. They are shouldered, so the thread is a slightly smaller diameter than the shoulder. Worth a try - saves a complete stripdown plus a gasket set.
John :)
John :)
That would be like trying to pick a lock on a windy night with a piece of wet string, good luck! :P
You are so right :P The end of these bolts have a square flange that sits into a square housing (surprisingly enough) so it would also be necessary to get these to locate.
Its such a chore - a complete stripdown for one stripped bolt......the punter doesn't like to pay either. Nowt new there then!
John :)
