asbestoes in artex was very common in the 1980s
So you didn't know that then?wow heard it all now![]()
Thanks, the driver bits look good. Do they also hold the screw while you are drilling so you can drill with just one hand?
I bought one of these it's ok but doesn't seem to hold the bit too well on its own.Thanks, the driver bits look good. Do they also hold the screw while you are drilling so you can drill with just one hand?
yes, magnetic
That's how the rest of the ceilings in the house were skimmed but the problem with the kitchen is that there is a 1 inch gap in the ceiling where a partition wall was removed (see photo in previous posting), also there are some lighting wires stuffed into this gap now so I think overboarding is the best solution?you could pva the lot, put a thin coat of bonding on to level it out, then when dry pva and skim, job done.
yes, magnetic
