Evening all,
I am about to gut my inherited 1970's 'champagne' bathroom. I've done this before, but this time 'er indoors has insisted upon a fully back-to-wall close-coupled toilet.
The waste will go through the wall (new hole) with a slight fall and then straight into a (solvent welded, probably) elbow. The entire cast iron stack above ground will be replaced with PVC (apart from bottom 12") since I can't face the necessary alterations.
Anyway, what's the best way of ensuring the pan connector is soundly connected to the bog? - clearly once 'home' it won't be visible. Is it just a case of getting the waste pipe in the correct position & pushing the pan into the connector and hoping, or is there a special technique?
(Had thought of connecting pipe to pan first and then poking the waste through from the inside, but then won't be able to make good around the hole in the brickwork.)
Many thanks in advance.
