Hi All,
We want to move out toilet from an Outside wall to an Inside wall.
Currently the toilet backs onto the outside wall and the waste pipe goes straight through the wall to the vertical soil pipe on the outside wall.
We want to move the toilet to an Inside wall - thus the soil pipe would run under the floor.
The new toilet outlet is straight from the back of the toilet the same as the old one.
We'll need one of these Pan connectors to allow the toilet to connect to the soil pipe under the floor.
http://www.screwfix.com/prods/15330...r-90º-Bend;jsessionid=U4TAPGH2D1GSCCSTHZOCFFY
What happens after that?
Can I connect the above Pan connector to a 90° 110mm angle?
If so, I assume I connect it to the "Female" end (the one with the rubber seal), but when I do this, the connection seems a bit loose with the pan connector moving around quite a lot on it's rubber seals.
Should I use a short piece of 110mm pipe to join the Pan Connector and 90° angle together?
Any Ideas / comments / suggestions gratefully received.
Cheers
Trent
Cheers
Trent
