Where does the heat in a house come from?
Google wrote
Energy coming from the sun arrives in the form of radiant energy. The sun emits a wide spectrum of frequencies, but considering visible light is enough for our purposes here. Glass has the property of allowing most low-frequency sunlight to pass through.
When this sunlight reaches the surfaces inside the home, they either absorb it or reflect it. Absorbing the light energy converts it to radiant heat. Glass is less transparent to this heat than visible light, so the heat is trapped inside the house.
This trapping of heat is called the greenhouse effect.
I see.
It's been that warm tonight I've had to pull the hood of my parka down.:shock:
Its -2 here and snowing.
I think the bee's are right.
a mid terrace has less than 20% outside walls compared to a normal house off around 45% plus around 10 to 15% off heat generated and hitting the connecting walls each side will transfer through the walls iff they are on around 22 degrees and you are on 12 degrees
a typical set up is front wall off the house 14ft wide external front room 13ft deep so front room up and down 73% internal
halway and stairs fully internal
back rooms up and down 1/2 a wall external so 13% external
typical kitchen and back room up stairs 50% external
as said above solar gain plus any excess heat from any electrical gadgets not venting outside
a person will give out up to a kw off heat
any way all that aside i live in a mid terrace my heating has so far this winter been on for less than 10 hours total the temperature has not dropped below 18 degrees in the main room when it does i turn the heating on for 30 mins
there is little solar gain in my house e.s.east facing other rooms in the house are cooler
hmmm, mid terrace here and without heating it is never below 19 degrees.
Have to admit fully insulated walls and ceilings.
Sun , when out on front all day.
Don't forget Joe, your computer kicks some heat out, plus the fridge/freezer. Plus, it always seems warmer if your inside out of the wind (the chill factor comes into effect) All these factors come into consideration, plus all the visitors you undoubtedly have. Their body heat adds to the heat inside your abode. :wink: :wink: :wink: :wink: :wink: :wink:
Joe, if you have more than one username, would that mean you emit more heat than just a single person? :wink:
If the heat in the house comes from sun and light - why is it cool in summer and warm in winter?
outside air temperature in bright sunlight say 25-30 degrees in direct sunlight say 40 to 45 degrees temperature 22 degrees so half the outside temperature
outside temperature say o-10 degrees inside say 15 degrees so double the outside temperature :wink:
No. It's just the same when you go to any empty house - even one that's been empty for years. I went into an Anderson shelter once - it's nearly always the same temperature - summer or winter according to the owner. And coal mines are warm too.
I went into a Nissan Hut once - they make cars too , according to the owner.
You do know the Sun and the Moon are the same thing don't you? And there's more than one? The Suns are switched on and hot in the day then at night are turned off and so go cold, we call them Moons. They then get switched back on in the morning. Possibly someone left the Sun over Joe's house turned on. There are many reasons it could be warm in your house Joe, but that's the most obvious. Check it out.
Stay tuned for tomorrows lesson in "on a scale of 1 to 10 just how flat is the earth". :shock:
