    Dismiss Notice
Where does the heat in a house come from?
Discussion in 'General Discussion' started by joe-90, 4 Dec 2011.
  1. Norcon
    Norcon
    17 May 2008
    8,417
    Thanks Received:
    357
    Country:
    Google wrote
  2. Sponsored Links
  3. joe-90
    joe-90
    28 Oct 2005
    31,284
    Thanks Received:
    1,062
    Country:
    I see.
    It's been that warm tonight I've had to pull the hood of my parka down.:eek:
  4. Norcon
    Norcon
    17 May 2008
    8,417
    Thanks Received:
    357
    Country:
    Its -2 here and snowing.
    I think the bee's are right.
  5. big-all
    big-all
    12 Jul 2004
    18,735
    Thanks Received:
    1,463
    Surrey
    Country:
    a mid terrace has less than 20% outside walls compared to a normal house off around 45% plus around 10 to 15% off heat generated and hitting the connecting walls each side will transfer through the walls iff they are on around 22 degrees and you are on 12 degrees
    a typical set up is front wall off the house 14ft wide external front room 13ft deep so front room up and down 73% internal
    halway and stairs fully internal
    back rooms up and down 1/2 a wall external so 13% external
    typical kitchen and back room up stairs 50% external
    as said above solar gain plus any excess heat from any electrical gadgets not venting outside
    a person will give out up to a kw off heat
    any way all that aside i live in a mid terrace my heating has so far this winter been on for less than 10 hours total the temperature has not dropped below 18 degrees in the main room when it does i turn the heating on for 30 mins
    there is little solar gain in my house e.s.east facing other rooms in the house are cooler
  6. Alarm
    Alarm
    18 Oct 2010
    8,965
    Thanks Received:
    532
    London
    Country:
    hmmm, mid terrace here and without heating it is never below 19 degrees.
    Have to admit fully insulated walls and ceilings.
    Sun , when out on front all day.
  7. joinerjohn
    joinerjohn
    28 Nov 2009
    6,145
    Thanks Received:
    201
    Derby
    Country:
    Don't forget Joe, your computer kicks some heat out, plus the fridge/freezer. Plus, it always seems warmer if your inside out of the wind (the chill factor comes into effect) All these factors come into consideration, plus all the visitors you undoubtedly have. Their body heat adds to the heat inside your abode. ;) ;) ;) ;) ;) ;)
  8. LooPrEvil
    LooPrEvil
    23 Nov 2009
    1,636
    Thanks Received:
    53
    Anglesey
    Country:
    Joe, if you have more than one username, would that mean you emit more heat than just a single person? ;)
  9. joe-90
    joe-90
    28 Oct 2005
    31,284
    Thanks Received:
    1,062
    Country:
    If the heat in the house comes from sun and light - why is it cool in summer and warm in winter?
  10. Sponsored Links
  11. big-all
    big-all
    12 Jul 2004
    18,735
    Thanks Received:
    1,463
    Surrey
    Country:
    outside air temperature in bright sunlight say 25-30 degrees in direct sunlight say 40 to 45 degrees temperature 22 degrees so half the outside temperature
    outside temperature say o-10 degrees inside say 15 degrees so double the outside temperature ;)
  12. 'cos its where they dumped all the spent fuel from Sellafield.
  13. Nige F
    Nige F
    28 Jun 2005
    21,154
    Thanks Received:
    1,729
    Country:
    I went into a Nissan Hut once - they make cars too , according to the owner.
  14. gcol
    gcol
    22 Sep 2005
    6,593
    Thanks Received:
    68
    Preston, Lancashire
    Country:
    You do know the Sun and the Moon are the same thing don't you? And there's more than one? The Suns are switched on and hot in the day then at night are turned off and so go cold, we call them Moons. They then get switched back on in the morning. Possibly someone left the Sun over Joe's house turned on. There are many reasons it could be warm in your house Joe, but that's the most obvious. Check it out.
    Stay tuned for tomorrows lesson in "on a scale of 1 to 10 just how flat is the earth". :eek:
  15. joe-90
    joe-90
    28 Oct 2005
    31,284
    Thanks Received:
    1,062
    Country:
    Then why is it cool in summer?
  16. cantaloup63
    cantaloup63
    29 Jul 2011
    3,368
    Thanks Received:
    86
    Manchester
    Country:
    It's all relative
  17. joe-90
    joe-90
    28 Oct 2005
    31,284
    Thanks Received:
    1,062
    Country:
    To what?
Loading...
Share This Page
