Cheers westie, I only browsed over the thread so missed that.The OP states he installs 13A RCD plugs
Well, I did askDont ask ... the OP will tell you. Mostly domestic but with the occasional pub, social club, shop thrown in.
Do you not see a problem (at least, in terms of regs, even if one would probably have to wait a few lifetimes to see a consequent incident) in a 0.75mm² cable protected by a 13A fuse?I don't see too much of a problem, providing the flex used is suitable for the environment.
Now there is a problem!Do you not see a problem (at least, in terms of regs, even if one would probably have to wait a few lifetimes to see a consequent incident) in a 0.75mm² cable protected by a 13A fuse?
Kind Regards, John.
The OP has indicated that the light tracks come fitted with 0.75mm² cable and that, where necessary, he extends with cable of the same size (we haven't {yet} asked him how he makes the join!). When there is also a heater he uses a 13A fuse, so there is clearly a theoretical problem of cable protection if he combines lighting and heater cables together.Now there is a problem! ... But did the units come pre-fitted with flex and what do the MI state?Do you not see a problem (at least, in terms of regs, even if one would probably have to wait a few lifetimes to see a consequent incident) in a 0.75mm² cable protected by a 13A fuse?
Yes, that's how it seems.So what i glean from this thread is that the way i have been installing my awnings, lighting & heaters doesnt not conform entirely to regulations.
At least partially. Any cable less than 1.25mm² needs to be protected by a fuse smaller than 13A (i.e. 3A or 5A) - so awning and lighting would come from the load side of an FCU and the heater from the 'input' side of the FCU (the side connected via a cable to the plug/socket).But the use of a fcu with respective fusing at the point were i normally use an ordinary jb would cure the problem in respect of safety in regards to protecting the lighting cable (& the awning cable as well as it 1.0mm 3 core)?
There are several issues being discussed here, so I'm not sure which one you refer to. As far as cable protection is concerned, even if one forgets about BS7671, I don't think that a 0.75mm² or 1mm² cable protected by a 13A fuse would be considered 'safe' (e.g. by part P, which always applies - in dwellings), whatever we may think of the chances of it ever coming to harm!John That was my original point, why does BS7671 have to be involved as long as the installation is safe? As it is pretty non-standard I doubt 7671 would be of any use (apart to scheme members that have no choice)
Yes.Fitting LCD or Plasma TV's to a wall is quite common, often householders use trunking or oval conduit to tidy up flex (and aerial wires) goint to the TV. Does this make it fixed wiring?
It doesn't.That was my original point, why does BS7671 have to be involved as long as the installation is safe?
Very little of the 3 pages has actually been about notifiability. Most of it has related to whether or not the OP's long-standing practices are fully compliant with regulations (e.g. BS7671) and/or legislation (e.g. Part P) - and I think we can agree that, at least in some cases, they are not.But as for the rest of the 3 pointless pages of back-and-forth, why don't you all do the simple thing, and read Schedule 4 and see if you can find any match for the installation of new powered awnings and new heaters which makes them non-notifiable?
