Having researched past threads and google I was hoping I could get some feedback on my plans for converting part of my garage into a music practice room before I get into planning it in detail.
The garage is single skin block with a pitched roof, I'll be taking the back half with the new room interior roughly 3.25m by 2m with a height of 2.4m. I'll be incorporating the existing uPVC side door into the room.
Here's a rough layout, grey is block, black door and red new stud.
And a side view
I'm not after complete sound isolation and won't be doing anything that loud (guitars, vocals etc) in there but would like to keep as much sound in as possible.
How does this sound:
• Stud and thicker plasterboard throughout, hopefully double thickness if the budget will cover it.
• The roof trusses are in just the right place so I was planning to use them to attach the headers for the two long side walls to.
• the dividing wall I was planning on making double thickness with a stud frame on both sides of the roof truss and double insulation more for heat retention than sound.
• similarly a big gap and loads of insulation in the roof/ceiling.
• the garage side of the dividing wall and flat across the top I was going to face with thick ply like you see windows boarded up with
• floor will be a wooden frame with insulation and ply or chipboard flooring sheets and just sat on the concrete within but not attached directly to the walls.
• I'll lay damp proof membrane under the whole thing and hang between the stud frames and block walls.
A few sound proofing specific questions:
• Is neoprene worthwhile to limit coupling to the existing structure (between structure and floor, block walls etc)?
• Is it worth the effort of building a room within a room ie just sitting on the floor and not tied into the garage walls, trusses etc?
And a side view
