12V Outdoor Downlights - Any recommendations?
17 Apr 2011
UK
Hi all,
I think this is the correct place to post this
I am looking at installing some downlights above my two garage doors, two lights per door, one at the left and one at the right of each door. I am going to install them in the soffit.
I am capable of installing them, it's just I'm struggling to find the lights themselves so I would like some advice
I want something like this but obviously they need to be suitable for outdoor use.
I also want ones with a low power consumption
I am struggling to find something like this reasonably priced on the internet
Does anyone have any suggestions of lights / parts that I could use, I do not want to spend any more than £100 on the whole setup
Also, any other tips / tricks would be welcome :)
Hope you can help, :)
Use IP44 ones. I just installed some with 4.3W LED GU10 lamps in them. Plenty bright enough.
Something like
http://www.everythingdiy.co.uk/products/Cast+Aluminium+IP44+FIXED+GU10+Downlight+in+White/4250667173
plus
http://www.tlc-direct.co.uk/Products/LTGU7NW.html[/QUOTE]
Thanks, wasn't sure on LED's though, don't you think they would be too directional for what I want? I want them to shine on the garage doors
Also, is there no 12V alternative or anything that will save power as I want to have them on everyday when it gets dark, up until about midnight?
Thanks for your help, :)
Also, is there no 12V alternative or anything that will save power as I want to have them on everyday when it gets dark, up until about midnight?)
Quote Tlc- "Using less than 5w of power, these are the ultimate energy saving lamp."
:P
Aha I did read read that and I know LEDs hardly use any power but but like I said would LEDs not be too directional and just shine at the ground rather than shine onto the garage doors and the ground?
What do you think?
Won't all MR16 lamps do that?
Isn't that why another common name for those lights is "spotlights"?
What about a couple of low-profile surface mounted lights? You could put CFLs or LED lamps in, or quite possibly find some that use LEDs by design.
You did highlight
Those LEDs have a
Beam Angle: 38°
Which is about the same as many downlight lamps.
If you want to point them look for adjustable downlights as they can be tilted.
IP44 is the preferred requirement to protect against occassional water ingress but, quite frankly, they wont get wet under a soffit unless you spray them with a hosepipe.
Is it just me, or is there something really naff about downlights in soffits?
Around here they seem to be the new stone cladding on all the council estates. That and Corinthian columns. :x
Or is there a different class system in Cambridgeshire? :lol:
Do you actually want the lights to shine on the doors?
Or do you want them to light the uprights when you drive (or, more properly, reverse) in?
12V isn't the criterion which saves power. It's the wattage you need to consider.
Hmmm, I have never actually looked into the difference between the beam angle of GU10/MR16 bulbs and LED style ones, I just always thought that LEDs were more directional than the others
I will have to do some research into the beam angles available
Any links to the lights you mean, like the low profile surface mounted ones? I think Dad really wants the hidden away, recessed style ones though
You did highlight
Those LEDs have a
Beam Angle: 38°
Didn't think they'd get wet, I was going to install some indoor ones that I have, but I only have two of them, so I thought I might as well use them indoors somewhere, and get 4 'outdoor' ones for the garage. I will look for some IP44 ones :)
Aha, no, I think they look nice, lol :) Not many people around here have them, hardly any to be honest
Hmmmm ok, I'm not sure about whether they are going to be pointing at the doors or the uprights, they are actually for my Dad, I'm just doing the question asking here for him. I will ask him and get back to you
OK, thanks for the info about wattage, I will bear that in mind
So you're just saying 240V ones ... with a low watt bulb? Like the LED ones mentioned above?
Something like
plus
Have you got / can you get any pictures of these lights that you installed? Would be great if you could :)
I might get LEDs as that is what my Dad had originally suggested as they look nicer (and they are cheap to run, so it is an extra bonus), and a lot of you here don't seem to think the beam angle of LEDs would be an issue, especially if they are tilt-able lights like taylortwocities recommended
Thanks for all the help :)
Ha.
Try driving round the Costwolds and find any house (council or private) built in the last 20 years (or possibly longer) where what you see is real stone construction and not thin Cotswold stone slips cladding lightweight blocks.
I was thinking more the Jack Duckworth variety :D
I dare say soffit downers (if that doesn't sound too disparaging) could possibly look classy on some nice garage doors. I'd be inclined to opt for the LED type, if only as they're going to be left on all evening (in dark nights) you can rest in the knowledge the environmental issue will be negligable.
I would consider wiring them into a PEC (photo elec cell), as well as a timeswitch that puts them off at your desired time. That way you can just forget about them, and they'll come on at dusk every evening. (Maybe you already have).
... only run for a certain period after it gets dark. Not all night.
Problem there is it's a case of, winter they go off early, summer on all night. As I understand it, you're still left with needing to adjust through the seasons. Not much advantage over a standard timeswitch.
