Help with connector size
24 Jan 2012
London
Hi all, first post but been using the helpful tips for a while...
I'm renovating a bathroom and installing pipes for thermostatic shower into the brick wall that will be tiled later.
My question is regarding the default size of the female connector for the shower mixer... I will have 2 of them 150mm apart, but not sure if it should be 1/2 female or 3/4 female.... or even male... bit confused.... :?
I'm running 15mm copper pipes up.
Thanks in advance
haven't bought it yet, but will probably get a triton excellente thermostatic shower...
but I thought there was a default size regardless of the shower...
The bar mixer has 3/4" nuts that screw on to 3/4"x1/2" doglegs.
The doglegs are secured in the wall onto 1/2" wall plate.
great, thanks for the info... but just to make sure... I need then 1/2" female in the wall, right?
better safe than sorry...
yes i've shown the brass wall plate that connects to the 15mm copper pipes.
or fit these dam sight easier to install.
