Hi there,
I have a 7.5kW shower that is being protected by a 40A fuse - it is an old consumer unit, but I am hoping to get this replaced later this year.
Anyway, I have an external isolation switch for the shower on the wall outside and it has occurred to me that it might not be up to scratch.
I did some research and I have read that external shower switches require a fuse, a neon light and be double pole.
My switch is white with a red switch mechanism (no light on it) and I had a quick look inside and there is no fuse (I assume I am looking for a larger version of a plug fuse?).
Do you think I should replace this switch and, if so, with what rated fuse?
Also, two quick questions, just for my own learing:
1. Why does this switch have to be fused, given it is protected by the fuse in the consumer unit. Is it simply a belt and braces approach?
2. What exactly is a double pole switch as compared to a single pole and why is required for shower switches?
Thanks very much.
A
Thanks very much.
A
