After some advice hopefully if anyone can help.
Just moved into a detached house, which is costing a LOT in gas bills, so I just wondered what the best way was to be operating the central heating (radiators with combi boiler). The house gets relatively cold as it doesn't get any sun in it at all, but is well insulated and has uPVC double glazing.
We've turned the boiler's hot water temperature down to as low as we can live with it.
What setting should we have the heating dial to on the boiler?
There's a wireless thermostat in the living room, which is set to 19°. There are 2 large radiators in the room (quite a small room really), which have their thermo valves removed (so effectively not temperature-controlled, turned only on/off by the main thermostat), and have radiator cabinets over them. They get very hot, and you often have a blast of hot air when you walk in the room, even if the doors are open (they usually are).
We also have a separate dining room, and we keep that radiator on 3, and the door shut during the day. This has the effect of making the room almost ice cold when the doors are shut for some reason, so if we know we're going to use it, we have to keep the doors open for a bit to heat it up.
All other radiators in the house (inc. hall/bathrooms/kitchen) are set either on 2 or 3 depending on their purpose (kitchen has a cabinet over it, and is set to 2); and master bedroom door is closed during the day as we have a dog that we want to keep out of the room. All other doors in the house are either open or pushed to (but not closed).
Heating comes on at 19° half an hour before we get up, and goes down to 16° half an hour after we go to bed. If we're out for the day, we turn it down to 17° before we go out. I work from home in a room I use as an office, so unfortunately need the house heated during the day, though obviously not the upstairs (though I don't really want to be messing about with the radiator thermo valves upstairs every day).
So, I guess my question is: what can I do better to significantly reduce my heating bills?
-What setting should I have the actual boiler dial on?
-Is it best to have the wireless thermostat situated in the living room all the time (inc. during the day when I'm working in another room)?
-Am I right to have removed the thermo valves from the 2 living room radiators (that are in cabinets)?
-Is the temp setting of 2 on radiators in e.g. the bathrooms/hall/landing/kitchen okay; with bedrooms/living room/dining room/office on 3?
-Is it okay to have most of the doors open, or better to keep individual rooms closed?
Any help would be greatly appreciated. We had a plumber round before Christmas, and asked him for advice, but he didn't have anything at all to offer, so hopefully someone on here will have some experience and knowledge!
Thanks in advance.
Thanks in advance.
