12V Outdoor Downlights - Any recommendations?
Hmmm, thanks for the options but I think I will stick with a standard timer
Please be aware that certain older soffits were made from Asbestos.
I will bear this in mind, the house is 7 years old, or do you mean much older than that?
I have had a look around and found these:
http://www.lyco.co.uk/Pro-Lite-Ultra-Beam-LED-GU10.aspx
http://www.lightusup.co.uk/lamps-li...volt-gu10--ip44-fixed-downlight/audlm412.html
Will those two work with each other? They seem reasonably priced too
The LED bulbs have a 60 degree beam angle too
Does anyone know what the light fittings will come with, as I've never bough lights like this before. I assume they will come with all the connections / fittings and all I need is the wire?
Hope you can help, :)
Lyco give the length as 57mm.
Not sure if that's supposed to include the pins. If not they're longer than normal, in which case they possibly won't go in.
OK Thanks, I will have a look for some different bulbs then :)
