1.3 duratec engine
  • Thread starter Thread starter peaps
  • Start date Start date
P
peaps
Is the 1.3 duratec engine in the Fiesta the same as the 1.3 duratec engine in the Ford KA?
Can they fit in each car?
i would have thought the engine is the same, whether the mountings and ancilliary components are the same is another matter.
Yes you are correct, the engine is the same. Comes to something when it's cheaper to replace the engine than it is to repair the thing!! Daughters car, she dropped a valve..
Ah there's more bent than the valve, best just to change the lot.
Might be worth comparing engine codes, less hassle if they are the same
Must be the same lump, worth having a good look at one to check engine mount points etc?
Just finished it, thanks for the replies. I priced the part to fix the engine not taking into account damage if any inside. Odds are the head would have needed some work. I got a lump for £240 delivered, 25,000 mile and 90 warranty, trusted supplier in Stoke.
Change were, engine mount, hydrolic pump, thermostat housing and rocker cover. Runs like a dream.
