Yes as holmslaw added just make sure the lights are on the same circuit and the circuit is dead when you make the swop - otherwise fuses will blow and so may yougreat thanks for that
so its just a case of putting the coms and L1s together for lights 1 and 2?
Do i need to worry about blowing fuses or any problems conecting them together?
Unless it was installed by someone who found it easier to run a T/E switch cable from each light.The live feed will be looped between the existing 1 and 2 switches.
If they have separate live feeds then your idea doesn't work.
