Hi
I am having problems with the above boiler rapidly losing pressure in a short space of time (ie 1.7bar to 0.0 overnight)
Have had glowworm tech out twice and he cannot find anything wrong with the boiler, he also did some kind of test to check for leaks in the system but couldn't find anything wrong there either so he was stumped!
I am just trying a test myself to isolate the boiler for a few hours to see if the pressure still drops. I know I have to turn the CH flow and return valves but should I also close the cold water in valve for this test to work? Also does it matte if the power is left on for the boiler?
Some other fault finding I ave done is to check the Rad valves, most of the rads have Drayton TRV-4 valves. If I take the head off and press down on the pin underneath then drops of water come out, is this normal or could faulty rad valves be the cause of the pressure drops?
