PIr lighting
7 Nov 2011
Fife
Hi.
I Am replacing security lighting on outside of mothers garage to give some light in dark area when coming in/out. Current ones leak and blown.
All wired through garage, at moment have 2 separate pir floodlights working independent but changing to either a 2 pir floodlight or 1 pir floodlight and
Non pir floodlight each 230 w , but wires so
Both come on simultaneously, most probably the latter. All cable is going to be replaced .
The pir light has LNE And
L1, with no instructions on L1.
Have read so many posts I am
Confused how to wire so that both will come on together.
Any advice is most welcome
Ks
changing to ... 1 pir floodlight and
Non pir floodlight each 230 w , but wires so Both come on simultaneously
The pir light has LNE And L1, with no instructions on L1.
Assuming than the non-PIR one has just LNE .... connect the supply to LNE of the PIR light in the normal way. Then have a cable from PIR light to non-PIR one, connecting L1, N and E of the PIR one to L, N and E respectively of the non-PIR one (no connection from L of the PIR one to the non-PIR one).
Others may well pop up with observations/questions about this work you intend to undertake.
Kind Regards, John.
